[Qgis-developer] Lizmap web client print tool
Andreas Neumann
a.neumann at carto.net
Fri Nov 7 02:54:38 PST 2014
hm - I can't tell you exactly what the problem is.
BUT: you cannot mix versions. If your server runs on QGIS 2.6, your
client where you prepare the project also needs to be of the same
version 2.6. Those different versions are not necessarily compatible.
It will open all sorts of problems if you mix version 2.0 and 2.6
Andreas
On 07.11.2014 11:23, Roy wrote:
> Dear list,
> i'm trying lizmap web client and can't get how the print tool
> is to be configured.
> I'm using ubuntu server 12.04 with qgis-server (2.6.0.);
> for the QGIS project i'm using QGIS 2.0.6.
> The Lizmap (2.10.0) demo works, also the print tool works for the demo
> project,
> so i think i'm doing somethin wrong with my configuration:
> for the test i set up a couple of vector layers and prepared a simple
> layout with QGIS composer with a map, legend and a title;
> anyway when i open the project the print icon does not appear
> in the lizmap toolbar, even if the print tool is checked in lizmap
> plugin;
> any hint or redirect to relevant documentation is very apreciated,
> thanks and compliments for the grat job with this tools,
> Roy.
> Qgis-developer mailing list
