[Qgis-developer] Lizmap web client print tool
Roy
royroge at outlook.com
Fri Nov 7 03:17:59 PST 2014
Il 07/11/2014 11.54, Andreas Neumann ha scritto:
> hm - I can't tell you exactly what the problem is.
> BUT: you cannot mix versions. If your server runs on QGIS 2.6, your
> client where you prepare the project also needs to be of the same
> version 2.6. Those different versions are not necessarily compatible.
Dear Andreas,
thanks for your replay,
actually i inverted 0 and 6 in my previous email sorry for the mess !
i'm using QGIS 2.6.0 both in client (Desktop) and server side.
Also i wonder if using QGIS desktop on Windows, to setup the project
and the composer template, is "safe" considering that the server is
Ubuntu/Linux...
anyway i'm not able to get the print tool to work preparing the project
and template
in Windows, nor in Linux ...
thanks again,
Roy.
