[Qgis-developer] Lizmap web client print tool
René-Luc Dhont
rldhont at gmail.com
Fri Nov 7 03:30:39 PST 2014
Hi Roy,
The documentation is not fully in english but the documentation exists
in French.
The page about configuring print is here :
http://docs.3liz.com/fr/publisher_guide/advanced_lizmap_config.html#configurer-l-impression
Do you have activated Print capabilities for the map in lizmap plugin ?
Regards,
René-Luc D'Hont
3Liz
Le 07/11/2014 12:17, Roy a écrit :
> Il 07/11/2014 11.54, Andreas Neumann ha scritto:
>> hm - I can't tell you exactly what the problem is.
>> BUT: you cannot mix versions. If your server runs on QGIS 2.6, your
>> client where you prepare the project also needs to be of the same
>> version 2.6. Those different versions are not necessarily compatible.
> Dear Andreas,
> thanks for your replay,
> actually i inverted 0 and 6 in my previous email sorry for the mess !
> i'm using QGIS 2.6.0 both in client (Desktop) and server side.
> Also i wonder if using QGIS desktop on Windows, to setup the project
> and the composer template, is "safe" considering that the server is
> Ubuntu/Linux...
> anyway i'm not able to get the print tool to work preparing the
> project and template
> in Windows, nor in Linux ...
> thanks again,
> Roy.
> Qgis-developer mailing list
