[Qgis-developer] Lizmap web client print tool
Roy royroge at outlook.com
Fri Nov 7 06:27:26 PST 2014
Ddear Renè-Luc,
thanks for you answer
Il 07/11/2014 12.30, René-Luc Dhont ha scritto:
> Hi Roy,
> The documentation is not fully in english but the documentation exists
> in French.
> The page about configuring print is here :
> http://docs.3liz.com/fr/publisher_guide/advanced_lizmap_config.html#configurer-l-impression
> Do you have activated Print capabilities for the map in lizmap plugin ?
Yes indeed, in the "Map" tab of the Lizmap plugin i activated the
"Simple print" option
from the docs you pointed (i don't know french sadly) but with Google
Translate i understand that
only the map element is mandatory and other elements can be set up as
north arrow and legend etc..;
the template i'm testing only has a map element in A4 landscape page
in the apache log i get
[Thu Nov 06 16:25:37 2014] [error] [client 127.0.0.1] Warning 1: Unable
to find driver JP2ECW to unload from GDAL_SKIP environment variable.
to find driver ECW to unload from GDAL_SKIP environment variable.
but print in the "Lizmap Demo" works so maybe not related...
thanks again,
Roy
> Regards,
> René-Luc D'Hont
> 3Liz
> Le 07/11/2014 12:17, Roy a écrit :
>> Il 07/11/2014 11.54, Andreas Neumann ha scritto:
>>> hm - I can't tell you exactly what the problem is.
>>> BUT: you cannot mix versions. If your server runs on QGIS 2.6, your
>>> client where you prepare the project also needs to be of the same
>>> version 2.6. Those different versions are not necessarily compatible.
>> Dear Andreas,
>> thanks for your replay,
>> actually i inverted 0 and 6 in my previous email sorry for the mess !
>> i'm using QGIS 2.6.0 both in client (Desktop) and server side.
>> Also i wonder if using QGIS desktop on Windows, to setup the project
>> and the composer template, is "safe" considering that the server is
>> Ubuntu/Linux...
>> anyway i'm not able to get the print tool to work preparing the
>> project and template
>> in Windows, nor in Linux ...
>> thanks again,
>> Roy.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
