[Qgis-developer] Lizmap web client print tool
René-Luc Dhont
rldhont at gmail.com
Fri Nov 7 07:02:02 PST 2014
Hi Roy,
I take a look at the commit list in lizmap-web-client release 2.10 and
we fixed this bug after the release.
https://github.com/3liz/lizmap-web-client/commits/release_2_10
We need to publish a bugfix release just for QGIS 2.6. The issue is due
to the new way to define overview in the QGIS Project XML.
You can download an intermediate here :
https://github.com/3liz/lizmap-web-client/archive/release_2_10.zip
Regards,
René-Luc D'Hont
3Liz
Le 07/11/2014 15:27, Roy a écrit :
> Ddear Renè-Luc,
> thanks for you answer
> Il 07/11/2014 12.30, René-Luc Dhont ha scritto:
>> Hi Roy,
>> The documentation is not fully in english but the documentation
>> exists in French.
>> The page about configuring print is here :
>> http://docs.3liz.com/fr/publisher_guide/advanced_lizmap_config.html#configurer-l-impression
>> Do you have activated Print capabilities for the map in lizmap plugin ?
> Yes indeed, in the "Map" tab of the Lizmap plugin i activated the
> "Simple print" option
> from the docs you pointed (i don't know french sadly) but with Google
> Translate i understand that
> only the map element is mandatory and other elements can be set up as
> north arrow and legend etc..;
> the template i'm testing only has a map element in A4 landscape page
> in the apache log i get
> [Thu Nov 06 16:25:37 2014] [error] [client 127.0.0.1] Warning 1:
> Unable to find driver JP2ECW to unload from GDAL_SKIP environment
> variable.
> Unable to find driver ECW to unload from GDAL_SKIP environment variable.
> but print in the "Lizmap Demo" works so maybe not related...
> thanks again,
> Roy
>> Regards,
>> René-Luc D'Hont
>> 3Liz
>> Le 07/11/2014 12:17, Roy a écrit :
>>> Il 07/11/2014 11.54, Andreas Neumann ha scritto:
>>>> hm - I can't tell you exactly what the problem is.
>>>> BUT: you cannot mix versions. If your server runs on QGIS 2.6, your
>>>> client where you prepare the project also needs to be of the same
>>>> version 2.6. Those different versions are not necessarily compatible.
>>> Dear Andreas,
>>> thanks for your replay,
>>> actually i inverted 0 and 6 in my previous email sorry for the mess !
>>> i'm using QGIS 2.6.0 both in client (Desktop) and server side.
>>> Also i wonder if using QGIS desktop on Windows, to setup the project
>>> and the composer template, is "safe" considering that the server is
>>> Ubuntu/Linux...
>>> anyway i'm not able to get the print tool to work preparing the
>>> project and template
>>> in Windows, nor in Linux ...
>>> thanks again,
>>> Roy.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
