[Qgis-developer] Field Calculator "permanence"
Zoltan Szecsei
zoltans at geograph.co.za
Fri Nov 7 07:54:06 PST 2014
I'm using QGIS 2.6.0 on Win 7 x64 - installed via OSGEO4w
Is there a way to store your field calculator expression to always
process and update that specific field, should geometry be edited or
created for that Layer?
Let's say I want to create a blank POINT shape file, with a text
attribute called "Sheet".
Whenever a POINT is created or moved, I want this field to be
dynamically updated with:
tostring(abs(toint($y)))+tostring(abs(toint($x)))
For testing thus far have:
* created 2 points
* Opened the field calculator, clicked 'Update Existing Field' and put
in the expression.
* The two existing points now have the correct TEXT values in the
Sheet field
* I close the Field calculator
* Create a new point in my layer
* open the attribute table to find that the 'Sheet' field for this new
point is blank
* I open the Field Calculator and I cannot even find a way to call
back the previous expression I used.
Am I using the correct QGIS functionality to achieve what I need to, and
if so, where am I going wrong?
Thanks & regards,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141107/7bfb9fbd/attachment.html>
