[Qgis-developer] qgis2threejs issue
Minoru Akagi
akaginch at gmail.com
Sun Nov 9 19:56:38 PST 2014
Hi Paolo,
2014-10-31 18:22 GMT+09:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 31/10/2014 09:58, Minoru Akagi ha scritto:
>> You need to take some steps. Do not change view extent of map canvas
>> while these steps:
>> 1. save the map canvas as a PNG image.
>> 2. set the background color as PNG transparent color using a photo
>> editor. I used IrfanView for this purpose.
>> 3. in the plugin dialog, select the image file option in the display
>> type group and enter the file path in the edit box.
>> 4. set transparency to 1% to enable transmission, and uncheck the
>> build sides option.
>> 5. do export
> works smoothly, thanks. IMHO it would be better to make all this automatic.
> should I open another ticket?
I think an option to make the background color of map canvas
transparent is useful. Also, if image file has a transparent color
(GIF) or alpha channel (RGBA PNG), the transmission option should be
automatically enabled.
Please open a ticket if you like.
Regards,
Minoru
