[Qgis-developer] QGIS 2.6 - Open postgis raster: decimal separator problem?
Jorge Gustavo Rocha
jgr at di.uminho.pt
Thu Nov 13 17:00:01 PST 2014
Hi devs,
I'm unable to open Postgis rasters using the default language setting,
which is pt_PT.UTF-8 in my case. By overriding language settings, I can
open Postgis rasters. Maybe something related with the decimal_point
setting in LC_NUMERIC?
I didn't find any bug related with this issue. Can some else confirm
this problem? Should I submit a bug?
How to reproduce the problem (if decimal_point == ',' and not '.'):
0) Download raster from https://bo5r0b.s.cld.pt or use your own raster
i) Insert raster in to Postgis
raster2pgsql -d -I -C -M -s 3763 001972Argb_12.tif -F -t 1000x1000 orto
| psql -h localhost -U geobox -d orto
ii) Open QGIS with default language settings.
Add raster to QGIS using DB Manager
iii) The raster does not show properly. Raster properties are not
extract/calculated correctly.
How to solve the problem:
i) Start QGIS overriding all language specific settings:
LC_ALL=C qgis
ii) The Postgis raster shows properly and all properties are loaded with
correct values.
I'm using:
Ubuntu 14.04.1 LTS
"PostgreSQL 9.3.5 on x86_64-unknown-linux-gnu, compiled by gcc (Ubuntu
4.8.2-19ubuntu1) 4.8.2, 64-bit"
"POSTGIS="2.1.2 r12389" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.9.1"
LIBJSON="UNKNOWN" RASTER"
QGIS version 2.6.0-Brighton QGIS code revision exported
Compiled against Qt 4.8.6 Running against Qt 4.8.6
Compiled against GDAL/OGR 1.10.1 Running against GDAL/OGR 1.10.1
Compiled against GEOS 3.4.2-CAPI-1.8.2 Running against GEOS
PostgreSQL Client Version 9.3.4 SpatiaLite Version 4.1.1
QWT Version 5.2.3 PROJ.4 Version 480
QScintilla2 Version 2.8.1
Additional feedback is appreciated.
Regards,
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
