[Qgis-developer] Groups in Layers panel
Roy
royroge at outlook.com
Fri Nov 14 00:22:08 PST 2014
Il 14/11/2014 07.23, Zoltan Szecsei ha scritto:
> Hi,
> I'm dealing with quite a number of vector map tiles, and I have
> grouped many of them with a common theme.
If your data have a common theme i suppose they are all belonging to the
same dataset so
maybe merging the data will solve the problem...
> What I'm finding pretty unworkable, is that when I want to set
> rendering style, I have to do it individually per map in that group,
> and likewise, when I want to Identify a feature within that group, I
> have to click through each map in that group in order to find which
> map in that group holds the feature I want to identify.
> There are probably quite a few other actions that would be easier to
> work at a group level rather than a map level,
> but:
> Am I attacking this issue the wrong way, or is there a possibility
> that some of these actions can be processed by QGIS at a map-group level?
> Regards to all,
> Zoltan
