[Qgis-developer] QGIS 2.6.0 georeferencer fails in windows
Roy
royroge at outlook.com
Fri Nov 14 02:14:14 PST 2014
Hi
Il 14/11/2014 10.47, Jonathan Moules ha scritto:
> Hi Roy,
> I just did a quick one and it worked; Windows using the stand alone installed version, 64bit I think.
> Which transformation are you using? I tested polynomial 1.
> That said, if it's repeatable, it's probably worth reporting as a bug anyway; including the sample data and detailed info.
> Cheers,
> Jonathan
The problem is happening with "big" raster (5680 x 4848), i tested it on
a smaller one and it worked;
even though the process is failing i get an output with only a quarter
of the image processed ...
it fails with any kind of transformation ...
to test it must be used a 32bit install because possibly 64bit do not
split the data during the transform process
Roy.
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Roy
> Sent: Friday, November 14, 2014 9:35 AM
> To: QGIS Developer Mailing List
> Subject: [Qgis-developer] QGIS 2.6.0 georeferencer fails in windows
> Dear list,
> i'm georeferencing some rasters and the georeferencing process fails (in winodows osgeo4w 32bit) with this message:
> failed to compute GCP transform: Transform is not solvable
> the georeferencing process works in linux using the very same data (raster and GCP list) is it only my system or should i open a bug report ?
> thanks,
> Roy.
> Qgis-developer mailing list
> This message has been scanned for viruses by MailControl - www.mailcontrol.com
> Click https://www.mailcontrol.com/sr/!U2xHBz6!6PGX2PQPOmvUgfUspOYWKRbcUkhPk2aSypSSjzNKybY9IsDGAD0hjxQxXDcnlWWD4mTKOxjbsImtQ== to report this email as spam.
> ________________________________
> HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
> If you have received this message in error please advise us immediately and destroy all copies of it.
> HR Wallingford Limited
> Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
> Registered in England No. 02562099
