[Qgis-developer] Crash of QGIS 2.4 built on RHEL 6 with Qt 5.3
Dave Johansen
davejohansen at gmail.com
Fri Nov 14 13:58:06 PST 2014
I was just working on getting things packaged up to try and build a .rpm,
but when I run cmake now I get the following error:
CMake Error at CMakeLists.txt:247 (INCLUDE):
include could not find load file:
cmake/modules/ECMQt4To5Porting.cmake
Any ideas?
Thanks,
Dave
On Tue, Sep 9, 2014 at 8:03 AM, Dave Johansen <davejohansen at gmail.com>
wrote:
> Ya, my hope is to get everything packed up and included in EPEL. It will
> probably be a little bit until I get that all setup because there are a few
> dependencies that need to be packaged as well, but hopefully it won't be
> too long.
> Dave
> On Tue, Sep 9, 2014 at 12:00 AM, Matthias Kuhn <matthias.kuhn at gmx.ch>
> wrote:
>> Good job.
>> Can we hope for rpm files for these? Would be nice to offer them
>> officially.
>> Matthias
>> On Die 09 Sep 2014 00:34:36 CEST, Dave Johansen wrote:
>> > Yep, QWT and QWT-Polar were the offending libraries. Once I built a
>> > Qt5 version and used this, QGIS 2.4 loaded up just fine on RHEL 6.
>> > Thanks for the help,
>> > Dave
>> > On Mon, Sep 8, 2014 at 3:52 AM, Matthias Kuhn <matthias.kuhn at gmx.ch
>> > <mailto:matthias.kuhn at gmx.ch>> wrote:
>> > Hi Dave,
>> > Maybe it could be QWT (and QWT-Polar) which are linked against
>> > Qt4? You will probably have to recompile such dependencies as well.
>> > On Fri 05 Sep 2014 08:24:33 PM CEST, Dave Johansen wrote:
>> > On Thu, Sep 4, 2014 at 11:38 PM, Matthias Kuhn
>> > <matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>
>> > <mailto:matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>>>
>> > wrote:
>> > Hi Dave
>> > there is still Qt 4 involved (partially?) as the 4 in the
>> > end of
>> > this line indicates:
>> > #10 0x00007ffff3e24ce6 in __do_global_ctors_aux () from
>> > /usr/lib64/libQtCore.so.4
>> > Did you clean the build directory after the build attempts
>> > for master?
>> > I just did a complete clean build just to be sure and it had
>> > the same
>> > crash. The same crash happened. Here's the output from ldd
>> > grepped for qt:
>> > libQt5Sql.so.5 => /usr/lib64/libQt5Sql.so.5
>> > (0x000000357c400000)
>> > libQt5WebKit.so.5 => /usr/lib64/libQt5WebKit.so.5
>> > (0x0000003585200000)
>> > libQt5WebKitWidgets.so.5 =>
>> > /usr/lib64/__libQt5WebKitWidgets.so.5
>> > (0x0000003580000000)
>> > libqgis_core.so.2.4.0 =>
>> /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___core.so.2.4.0
>> > (0x00007faf1211c000)
>> > libqgis_gui.so.2.4.0 =>
>> /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___gui.so.2.4.0
>> > (0x00007faf11a01000)
>> > libqgis_analysis.so.2.4.0 =>
>> /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___analysis.so.2.4.0
>> > (0x00007faf11772000)
>> > libQt5Quick.so.5 => /usr/lib64/libQt5Quick.so.5
>> > (0x000000357c800000)
>> > libQt5Qml.so.5 => /usr/lib64/libQt5Qml.so.5
>> > (0x000000357b200000)
>> > libQt5OpenGL.so.5 => /usr/lib64/libQt5OpenGL.so.5
>> > (0x000000357f400000)
>> > libQt5Sensors.so.5 => /usr/lib64/libQt5Sensors.so.5
>> > (0x000000357fc00000)
>> > libQt5Network.so.5 => /usr/lib64/libQt5Network.so.5
>> > (0x0000003579e00000)
>> > libQt5PrintSupport.so.5 =>
>> > /usr/lib64/libQt5PrintSupport.__so.5
>> > (0x000000357ee00000)
>> > libQt5Positioning.so.5 =>
>> /usr/lib64/libQt5Positioning.__so.5
>> > (0x000000357f800000)
>> > libQt5Xml.so.5 => /usr/lib64/libQt5Xml.so.5
>> > (0x000000357a200000)
>> > libQt5Concurrent.so.5 => /usr/lib64/libQt5Concurrent.__so.5
>> > (0x00007faf1133c000)
>> > libQt5Svg.so.5 => /usr/lib64/libQt5Svg.so.5
>> > (0x00007faf110eb000)
>> > libQt5Widgets.so.5 => /usr/lib64/libQt5Widgets.so.5
>> > (0x000000357ba00000)
>> > libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5
>> > (0x000000357aa00000)
>> > libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5
>> > (0x0000003578a00000)
>> > libQtSvg.so.4 => /usr/lib64/libQtSvg.so.4
>> (0x0000003582200000)
>> > libQtGui.so.4 => /usr/lib64/libQtGui.so.4
>> (0x00007faf0fda5000)
>> > libQtCore.so.4 => /usr/lib64/libQtCore.so.4
>> > (0x00007faf0f941000)
>> > So it looks like you already pointed out that the Qt4
>> > libraries are
>> > being linked in as well for some reason. Any ideas on what I
>> > should do
>> > to run down where this issue is coming from?
>> > For your other question (lrelease-qt5) you can revert this
>> > commit:
>> > 9c6f1698fcb3df758f024fad99ed65____06d6a38e0d
>> > I guess I'll have to figure out another approach to handle
>> > this
>> > suffix than just deleting it like this commit does.
>> > I reverted that commit and it built without me specifying the
>> > path to
>> > lrelease-qt5.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141114/3a654a12/attachment.html>
