[Qgis-developer] Crash of QGIS 2.4 built on RHEL 6 with Qt 5.3
Matthias Kuhn matthias.kuhn at gmx.ch
Fri Nov 14 16:05:01 PST 2014
The module should be there
https://github.com/qgis/QGIS/blob/qt5/cmake/modules/ECMQt4To5Porting.cmake
Don't know why it won't find it.
Matthias
On 14.11.2014 22:58, Dave Johansen wrote:
> I was just working on getting things packaged up to try and build a
> .rpm, but when I run cmake now I get the following error:
> CMake Error at CMakeLists.txt:247 (INCLUDE):
>   include could not find load file:
> Any ideas?
> Thanks,
> Dave
> On Tue, Sep 9, 2014 at 8:03 AM, Dave Johansen <davejohansen at gmail.com
> <mailto:davejohansen at gmail.com>> wrote:
>     Ya, my hope is to get everything packed up and included in EPEL.
>     It will probably be a little bit until I get that all setup
>     because there are a few dependencies that need to be packaged as
>     well, but hopefully it won't be too long.
>     Dave
>     On Tue, Sep 9, 2014 at 12:00 AM, Matthias Kuhn
>     <matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>> wrote:
>         Good job.
>         Can we hope for rpm files for these? Would be nice to offer them
>         officially.
>         Matthias
>         On Die 09 Sep 2014 00:34:36 CEST, Dave Johansen wrote:
>         > Yep, QWT and QWT-Polar were the offending libraries. Once I
>         built a
>         > Qt5 version and used this, QGIS 2.4 loaded up just fine on
>         RHEL 6.
>         > Thanks for the help,
>         > Dave
>         > On Mon, Sep 8, 2014 at 3:52 AM, Matthias Kuhn
>         > <mailto:matthias.kuhn at gmx.ch <mailto:matthias.kuhn at gmx.ch>>> wrote:
>         >     Hi Dave,
>         >     Maybe it could be QWT (and QWT-Polar) which are linked
>         against
>         >     Qt4? You will probably have to recompile such
>         dependencies as well.
>         >     On Fri 05 Sep 2014 08:24:33 PM CEST, Dave Johansen wrote:
>         >         On Thu, Sep 4, 2014 at 11:38 PM, Matthias Kuhn
>         <mailto:matthias.kuhn at gmx.ch> <mailto:matthias.kuhn at gmx.ch
>         <mailto:matthias.kuhn at gmx.ch>>>>
>         >         wrote:
>         >             Hi Dave
>         >             there is still Qt 4 involved (partially?) as the
>         4 in the
>         >         end of
>         >             this line indicates:
>         >             #10 0x00007ffff3e24ce6 in __do_global_ctors_aux
>         () from
>         >             /usr/lib64/libQtCore.so.4
>         >             Did you clean the build directory after the
>         build attempts
>         >         for master?
>         >         I just did a complete clean build just to be sure
>         and it had
>         >         the same
>         >         crash. The same crash happened. Here's the output
>         from ldd
>         >         grepped for qt:
>         >             libQt5Sql.so.5 => /usr/lib64/libQt5Sql.so.5
>         >         (0x000000357c400000)
>         >             libQt5WebKit.so.5 => /usr/lib64/libQt5WebKit.so.5
>         >         (0x0000003585200000)
>         >             libQt5WebKitWidgets.so.5 =>
>         >         /usr/lib64/__libQt5WebKitWidgets.so.5
>         >         (0x0000003580000000)
>         >             libqgis_core.so.2.4.0 =>
>          /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___core.so.2.4.0
>         >         (0x00007faf1211c000)
>         >             libqgis_gui.so.2.4.0 =>
>          /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___gui.so.2.4.0
>         >         (0x00007faf11a01000)
>         >             libqgis_analysis.so.2.4.0 =>
>          /home/dlj/projects/qgis-qt5/__build/../install/lib/libqgis___analysis.so.2.4.0
>         >         (0x00007faf11772000)
>         >             libQt5Quick.so.5 => /usr/lib64/libQt5Quick.so.5
>         >         (0x000000357c800000)
>         >             libQt5Qml.so.5 => /usr/lib64/libQt5Qml.so.5
>         >         (0x000000357b200000)
>         >             libQt5OpenGL.so.5 => /usr/lib64/libQt5OpenGL.so.5
>         >         (0x000000357f400000)
>         >             libQt5Sensors.so.5 => /usr/lib64/libQt5Sensors.so.5
>         >         (0x000000357fc00000)
>         >             libQt5Network.so.5 => /usr/lib64/libQt5Network.so.5
>         >         (0x0000003579e00000)
>         >             libQt5PrintSupport.so.5 =>
>         >         /usr/lib64/libQt5PrintSupport.__so.5
>         >         (0x000000357ee00000)
>         >             libQt5Positioning.so.5 =>
>         /usr/lib64/libQt5Positioning.__so.5
>         >         (0x000000357f800000)
>         >             libQt5Xml.so.5 => /usr/lib64/libQt5Xml.so.5
>         >         (0x000000357a200000)
>         >             libQt5Concurrent.so.5 =>
>         /usr/lib64/libQt5Concurrent.__so.5
>         >         (0x00007faf1133c000)
>         >             libQt5Svg.so.5 => /usr/lib64/libQt5Svg.so.5
>         >         (0x00007faf110eb000)
>         >             libQt5Widgets.so.5 => /usr/lib64/libQt5Widgets.so.5
>         >         (0x000000357ba00000)
>         >             libQt5Gui.so.5 => /usr/lib64/libQt5Gui.so.5
>         >         (0x000000357aa00000)
>         >             libQt5Core.so.5 => /usr/lib64/libQt5Core.so.5
>         >         (0x0000003578a00000)
>         >             libQtSvg.so.4 => /usr/lib64/libQtSvg.so.4
>         (0x0000003582200000)
>         >             libQtGui.so.4 => /usr/lib64/libQtGui.so.4
>         (0x00007faf0fda5000)
>         >             libQtCore.so.4 => /usr/lib64/libQtCore.so.4
>         >         (0x00007faf0f941000)
>         >         So it looks like you already pointed out that the Qt4
>         >         libraries are
>         >         being linked in as well for some reason. Any ideas
>         on what I
>         >         should do
>         >         to run down where this issue is coming from?
>         >             For your other question (lrelease-qt5) you can
>         revert this
>         >         commit:
>         >             9c6f1698fcb3df758f024fad99ed65____06d6a38e0d
>         >             I guess I'll have to figure out another approach
>         to handle
>         >         this
>         >             suffix than just deleting it like this commit does.
>         >         I reverted that commit and it built without me
>         specifying the
>         >         path to
>         >         lrelease-qt5.
Help getting QGIS to the next level of quality before November 15!
http://blog.vitu.ch/10102014-1046/crowdfunding-initiative-automated-testing
