[Qgis-developer] Write custom c++ application using QGIS under windows
Nejia
nejia at spaceyes.fr
Tue Nov 18 04:43:36 PST 2014
First you must download packages listed below from OSGeo4w ( http://qgis.org/en/site/forusers/download.html OSGeo4W Network Installer (32 or 64 bit)):
- qgis: QGIS desktop
- grass: GRASS GIS
- qgis-devel
- qt4-devel
- qt4-doc
- qt4-libs
- qwt-devel-qt4
- qwt-doc-qt
- qwt-libs-qt4
In the post of Denis just replace:
@set PATH=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\qgis-dev\bin;%PATH%
@set INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include;%OSGEO4W_ROOT%\apps\qgis-dev\include
With:
@set PATH=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\qgis\bin;%PATH%
@set INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include;%OSGEO4W_ROOT%\apps\qgis\include
(replace qgis-dev with qgis)
And if you want to build 64 bits applications with visual studio 2010 replace:
set VS90COMNTOOLS=C:\Program Files\Microsoft Visual Studio 9.0\Common7\Tools\ call "C:\Program Files\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86
with:
call "%PF86%\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" amd64 if exist "c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" call "c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" /x64 /Release path %path%;%PF86%\Microsoft Visual Studio 10.0\VC\bin
set SETUPAPI_LIBRARY=%PF86%\Microsoft SDKs\Windows\v7.0A\Lib\x64\SetupAPI.Lib
if not exist "%SETUPAPI_LIBRARY%" set SETUPAPI_LIBRARY=%PROGRAMFILES%\Microsoft SDKs\Windows\v7.1\Lib\x64\SetupAPI.lib
Cheers,
Nejia
-----Message d'origine-----
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de eliu1234
Envoyé : mardi 18 novembre 2014 00:15
À : qgis-developer at lists.osgeo.org
Objet : Re: [Qgis-developer] Write custom c++ application using QGIS under windows
I saw your post on this. And I actually used this .proj file. However, with all of your include directory, the header files qgisapplication.h does not exist in anyone of them. This is why I am confused about where it can be.
Re: Write custom c++ application using QGIS under windows Nov 17, 2014; 5:47pm — by 3nids 3nids Hi,
I wrote a post about that:
http://3nids.wordpress.com/2014/02/27/build-and-deploy-c-qgis-app-on-windows/
I hope it helps
Denis
Le mardi 18 novembre 2014, eliu1234 <[hidden email]> a écrit :
Thanks for the reply.
So after that, I should just include the directory containing the header files in .proj?
I tried to do this, however, i get the error in the following stackoverflow
post:
http://stackoverflow.com/questions/26597253/syntax-error-in-qgsapplication-h
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Write-custom-c-application-using-QGIS-under-windows-tp5173377p5173395.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at ...
http://lists.osgeo.org/mailman/listinfo/qgis-developer
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-developer <javascript:;>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Write-custom-c-application-using-QGIS-under-windows-tp5173377p5173412.html
Qgis-developer at lists.osgeo.org
