[Qgis-developer] Write custom c++ application using QGIS under windows
eliu1234
lby20102 at hotmail.com
Tue Nov 18 15:04:34 PST 2014
Thanks so much for the answer. I am able to get the 32 bit version working.
Right now, I am facing the problem of not able to run debug mode. Since all
those xxxxxd.lib files does not exist with the OSGeo4W installation. Do you
have any idea how to fix this?
And right now, I cannot seem to print anything in this mode. I tried to use
cout but my output line is not printed. I tried to setup using visual
studio. But is unsure how to include these dll files without their
corresponding library files. Do you have any idea on this?
Thanks.
In Reply To
Re: Write custom c++ application using QGIS under windows
Nov 18, 2014; 7:43am — by Nejia Nejia
First you must download packages listed below from OSGeo4w (
http://qgis.org/en/site/forusers/download.html OSGeo4W Network Installer (32
or 64 bit)):
- qgis: QGIS desktop
- grass: GRASS GIS
- qgis-devel
- qt4-devel
- qt4-doc
- qt4-libs
- qwt-devel-qt4
- qwt-doc-qt
- qwt-libs-qt4
In the post of Denis just replace:
@set PATH=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\qgis-dev\bin;%PATH%
@set
INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include;%OSGEO4W_ROOT%\apps\qgis-dev\include
With:
@set PATH=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\qgis\bin;%PATH%
@set
INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include;%OSGEO4W_ROOT%\apps\qgis\include
(replace qgis-dev with qgis)
And if you want to build 64 bits applications with visual studio 2010
replace:
set VS90COMNTOOLS=C:\Program Files\Microsoft Visual Studio
9.0\Common7\Tools\ call "C:\Program Files\Microsoft Visual Studio
9.0\VC\vcvarsall.bat" x86
with:
call "%PF86%\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" amd64 if exist
"c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" call
"c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" /x64 /Release
path %path%;%PF86%\Microsoft Visual Studio 10.0\VC\bin
set SETUPAPI_LIBRARY=%PF86%\Microsoft
SDKs\Windows\v7.0A\Lib\x64\SetupAPI.Lib
if not exist "%SETUPAPI_LIBRARY%" set
SETUPAPI_LIBRARY=%PROGRAMFILES%\Microsoft
SDKs\Windows\v7.1\Lib\x64\SetupAPI.lib
Cheers,
Nejia
View this message in context: http://osgeo-org.1560.x6.nabble.com/Write-custom-c-application-using-QGIS-under-windows-tp5173377p5173692.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
