[Qgis-developer] Write custom c++ application using QGIS under windows
Tendfly Niu
niubob at hotmail.com
Tue Nov 18 18:24:59 PST 2014
hi eliu1234,
The *.lib of QGIS should be created by compile. For the Qt's lib , e.g *d.lib. The qwt should download from OSGeo4W, so the qwt5.lib should found in OSGeo4W. The rest qt related packages should just install a Qt from http://qt-project.org/, when compiling API using cmake, it can automatically check the QT you installed before. Remember, the minimum version of QT QGIS-2X need is 4.7.0. hope this help.
> Date: Tue, 18 Nov 2014 15:04:34 -0800
> From: lby20102 at hotmail.com
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Write custom c++ application using QGIS under windows
> Thanks so much for the answer. I am able to get the 32 bit version working.
> Right now, I am facing the problem of not able to run debug mode. Since all
> those xxxxxd.lib files does not exist with the OSGeo4W installation. Do you
> have any idea how to fix this?
> And right now, I cannot seem to print anything in this mode. I tried to use
> cout but my output line is not printed. I tried to setup using visual
> studio. But is unsure how to include these dll files without their
> corresponding library files. Do you have any idea on this?
> Thanks.
> In Reply To
> Re: Write custom c++ application using QGIS under windows
> Nov 18, 2014; 7:43am ― by Nejia Nejia
> Hi,
> First you must download packages listed below from OSGeo4w (
> http://qgis.org/en/site/forusers/download.html OSGeo4W Network Installer (32
> or 64 bit)):
> - qgis: QGIS desktop
> - grass: GRASS GIS
> - qgis-devel
> - qt4-devel
> - qt4-doc
> - qt4-libs
> - qwt-devel-qt4
> - qwt-doc-qt
> - qwt-libs-qt4
> In the post of Denis just replace:
> @set PATH=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\qgis-dev\bin;%PATH%
> @set
> INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include;%OSGEO4W_ROOT%\apps\qgis-dev\include
> With:
> @set PATH=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\qgis\bin;%PATH%
> @set
> INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include;%OSGEO4W_ROOT%\apps\qgis\include
> (replace qgis-dev with qgis)
> And if you want to build 64 bits applications with visual studio 2010
> replace:
> set VS90COMNTOOLS=C:\Program Files\Microsoft Visual Studio
> 9.0\Common7\Tools\ call "C:\Program Files\Microsoft Visual Studio
> 9.0\VC\vcvarsall.bat" x86
> with:
> call "%PF86%\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" amd64 if exist
> "c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" call
> "c:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.Cmd" /x64 /Release
> path %path%;%PF86%\Microsoft Visual Studio 10.0\VC\bin
> set SETUPAPI_LIBRARY=%PF86%\Microsoft
> SDKs\Windows\v7.0A\Lib\x64\SetupAPI.Lib
> if not exist "%SETUPAPI_LIBRARY%" set
> SETUPAPI_LIBRARY=%PROGRAMFILES%\Microsoft
> SDKs\Windows\v7.1\Lib\x64\SetupAPI.lib
> Cheers,
> Nejia
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Write-custom-c-application-using-QGIS-under-windows-tp5173377p5173692.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141119/5622ec50/attachment-0001.html>
