Hi all, i'm testing Lizmap web Client with value relation to map values to be inserted in a point layer, with the edit tool values are correctly displayed with a "drop-down" list, but the layer popup only display the numerical key value used for the relation, do i need to setup a custom popup or is this feature not supported ? thanks, Roy.
