[Qgis-developer] Lizmap Relation value field
René-Luc Dhont rldhont at gmail.com
Mon Nov 17 11:39:38 PST 2014
Hi Roy,
It's the way that QGIS-Server returns feature info.
I thought that QGIS 2.6 has corrected this issue.
René-Luc D'Hont
3Liz
Le 17/11/2014 19:52, Roy a écrit :
> Hi all,
> i'm testing Lizmap web Client with value relation to map values
> to be inserted in a point layer, with the edit tool values are
> correctly displayed with a "drop-down" list, but the layer
> popup only display the numerical key value used for the relation,
> do i need to setup a custom popup or is this feature not supported ?
> thanks,
> Roy.
> Qgis-developer mailing list
