[Qgis-developer] Lizmap Relation value field
Roy royroge at outlook.com
Mon Nov 17 23:56:41 PST 2014
Thanks René-Luc,
regards,
Roy,
Il 17/11/2014 20.39, René-Luc Dhont ha scritto:
> Hi Roy,
> It's the way that QGIS-Server returns feature info.
> I thought that QGIS 2.6 has corrected this issue.
> René-Luc D'Hont
> 3Liz
> Le 17/11/2014 19:52, Roy a écrit :
>> Hi all,
>> i'm testing Lizmap web Client with value relation to map values
>> to be inserted in a point layer, with the edit tool values are
>> correctly displayed with a "drop-down" list, but the layer
>> popup only display the numerical key value used for the relation,
>> do i need to setup a custom popup or is this feature not supported ?
>> thanks,
>> Roy.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
