[Qgis-developer] Lizmap Relation value field
Roy
royroge at outlook.com
Tue Nov 18 03:36:15 PST 2014
Hi René-Luc
i searched for this issue in QGIS bug but cannot find it,
do you know if it's actually an open request?
because if this does not works the realtion value is
basically useless...
thanks Roy.
Il 17/11/2014 20.39, René-Luc Dhont ha scritto:
> Hi Roy,
> It's the way that QGIS-Server returns feature info.
> I thought that QGIS 2.6 has corrected this issue.
> René-Luc D'Hont
> 3Liz
> Le 17/11/2014 19:52, Roy a écrit :
>> Hi all,
>> i'm testing Lizmap web Client with value relation to map values
>> to be inserted in a point layer, with the edit tool values are
>> correctly displayed with a "drop-down" list, but the layer
>> popup only display the numerical key value used for the relation,
>> do i need to setup a custom popup or is this feature not supported ?
>> thanks,
>> Roy.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
