[Qgis-developer] Lizmap Relation value field
Andreas Neumann
a.neumann at carto.net
Tue Nov 18 04:44:04 PST 2014
Value relations work in QGIS server - if there are single values. If
there are multiple values (array) it doesn't work yet.
You need either QGIS 2.6 or master.
Andreas
Am 2014-11-18 12:36, schrieb Roy:
> Hi René-Luc
> i searched for this issue in QGIS bug but cannot find it,
> do you know if it's actually an open request?
> because if this does not works the realtion value is
> basically useless...
> thanks Roy.
> Il 17/11/2014 20.39, René-Luc Dhont ha scritto:
>> Hi Roy,
>> It's the way that QGIS-Server returns feature info.
>> I thought that QGIS 2.6 has corrected this issue.
>> René-Luc D'Hont
>> 3Liz
>> Le 17/11/2014 19:52, Roy a écrit :
>>> Hi all,
>>> i'm testing Lizmap web Client with value relation to map values
>>> to be inserted in a point layer, with the edit tool values are
>>> correctly displayed with a "drop-down" list, but the layer
>>> popup only display the numerical key value used for the relation,
>>> do i need to setup a custom popup or is this feature not supported ?
>>> thanks,
>>> Roy.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
