[Qgis-developer] Lizmap Relation value field
Roy
royroge at outlook.com
Tue Nov 18 05:38:53 PST 2014
Hi Andreas,
i'm using Lizmap web client release_2_10 and QGIS 2.6.0
i'm talking about Lizmap web client "info popup"
not displaying the relation "description" but
the numeric "code value" used for the relation mapping;
actually i don't know/uderstand if the problem is
in the client or server side; not claiming that the server is not working
nor the client ...
thanks,
Roy.
Il 18/11/2014 13.44, Andreas Neumann ha scritto:
> Hi,
> Value relations work in QGIS server - if there are single values. If
> there are multiple values (array) it doesn't work yet.
> You need either QGIS 2.6 or master.
> Andreas
> Am 2014-11-18 12:36, schrieb Roy:
>> Hi René-Luc
>> i searched for this issue in QGIS bug but cannot find it,
>> do you know if it's actually an open request?
>> because if this does not works the realtion value is
>> basically useless...
>> thanks Roy.
>> Il 17/11/2014 20.39, René-Luc Dhont ha scritto:
>>> Hi Roy,
>>> It's the way that QGIS-Server returns feature info.
>>> I thought that QGIS 2.6 has corrected this issue.
>>> René-Luc D'Hont
>>> 3Liz
>>> Le 17/11/2014 19:52, Roy a écrit :
>>>> Hi all,
>>>> i'm testing Lizmap web Client with value relation to map values
>>>> to be inserted in a point layer, with the edit tool values are
>>>> correctly displayed with a "drop-down" list, but the layer
>>>> popup only display the numerical key value used for the relation,
>>>> do i need to setup a custom popup or is this feature not supported ?
>>>> thanks,
>>>> Roy.
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
