[Qgis-developer] Lizmap Relation value field
Andreas Neumann
a.neumann at carto.net
Tue Nov 18 08:21:06 PST 2014
Hi Roy,
It is the responsibility of QGIS server to deliver the correct human
readable value instead of the code.
So make sure that QGIS server supports that. It works fine on my server.
Andreas
Am 2014-11-18 14:38, schrieb Roy:
> Hi Andreas,
> i'm using Lizmap web client release_2_10 and QGIS 2.6.0
> i'm talking about Lizmap web client "info popup"
> not displaying the relation "description" but
> the numeric "code value" used for the relation mapping;
> actually i don't know/uderstand if the problem is
> in the client or server side; not claiming that the server is not
> working
> nor the client ...
> thanks,
> Roy.
> Il 18/11/2014 13.44, Andreas Neumann ha scritto:
>> Hi,
>> Value relations work in QGIS server - if there are single values. If
>> there are multiple values (array) it doesn't work yet.
>> You need either QGIS 2.6 or master.
>> Andreas
>> Am 2014-11-18 12:36, schrieb Roy:
>>> Hi René-Luc
>>> i searched for this issue in QGIS bug but cannot find it,
>>> do you know if it's actually an open request?
>>> because if this does not works the realtion value is
>>> basically useless...
>>> thanks Roy.
>>> Il 17/11/2014 20.39, René-Luc Dhont ha scritto:
>>>> Hi Roy,
>>>> It's the way that QGIS-Server returns feature info.
>>>> I thought that QGIS 2.6 has corrected this issue.
>>>> René-Luc D'Hont
>>>> 3Liz
>>>> Le 17/11/2014 19:52, Roy a écrit :
>>>>> Hi all,
>>>>> i'm testing Lizmap web Client with value relation to map values
>>>>> to be inserted in a point layer, with the edit tool values are
>>>>> correctly displayed with a "drop-down" list, but the layer
>>>>> popup only display the numerical key value used for the relation,
>>>>> do i need to setup a custom popup or is this feature not supported
>>>>> thanks,
>>>>> Roy.
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
