[Qgis-developer] Lizmap Relation value field
Roy royroge at outlook.com
Tue Nov 18 10:46:36 PST 2014
Hi Andreas,
thanks for your answer
Il 18/11/2014 17.21, Andreas Neumann ha scritto:
> Hi Roy,
> It is the responsibility of QGIS server to deliver the correct human
> readable value instead of the code.
> So make sure that QGIS server supports that. It works fine on my server.
so do i need to recompile QGIS to activate this feature?
i searched for documentation but i cannot find anything relevant.
What i understand is that the configuration file for QGIS server is
the one saved with QGIS desktop...
maybe i need to edit this file to add more config parameter ?
also i cannot find documentation about those (if they exists) parameters
configuration...
thanks,
Roy.
> Andreas
> Am 2014-11-18 14:38, schrieb Roy:
>> Hi Andreas,
>> i'm using Lizmap web client release_2_10 and QGIS 2.6.0
>> i'm talking about Lizmap web client "info popup"
>> not displaying the relation "description" but
>> the numeric "code value" used for the relation mapping;
>> actually i don't know/uderstand if the problem is
>> in the client or server side; not claiming that the server is not
>> working
>> nor the client ...
>> thanks,
>> Roy.
>> Il 18/11/2014 13.44, Andreas Neumann ha scritto:
>>> Hi,
>>> Value relations work in QGIS server - if there are single values. If
>>> there are multiple values (array) it doesn't work yet.
>>> You need either QGIS 2.6 or master.
>>> Andreas
>>> Am 2014-11-18 12:36, schrieb Roy:
>>>> Hi René-Luc
>>>> i searched for this issue in QGIS bug but cannot find it,
>>>> do you know if it's actually an open request?
>>>> because if this does not works the realtion value is
>>>> basically useless...
>>>> thanks Roy.
>>>> Il 17/11/2014 20.39, René-Luc Dhont ha scritto:
>>>>> Hi Roy,
>>>>> It's the way that QGIS-Server returns feature info.
>>>>> I thought that QGIS 2.6 has corrected this issue.
>>>>> René-Luc D'Hont
>>>>> 3Liz
>>>>> Le 17/11/2014 19:52, Roy a écrit :
>>>>>> Hi all,
>>>>>> i'm testing Lizmap web Client with value relation to map values
>>>>>> to be inserted in a point layer, with the edit tool values are
>>>>>> correctly displayed with a "drop-down" list, but the layer
>>>>>> popup only display the numerical key value used for the relation,
>>>>>> do i need to setup a custom popup or is this feature not supported ?
>>>>>> thanks,
>>>>>> Roy.
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
