[Qgis-developer] Processing with raster files > 4GB
G. Allegri
giohappy at gmail.com
Wed Nov 19 01:21:03 PST 2014
> From my grayscale tiff images I want to replace one pixel value (249)
with white (255). All other pixels should stay at the value they have.
> I came across https://github.com/chiatt/gdal_reclassify - but this
reclassifies all pixels, not only selected ones.
> Maybe I could use http://www.gdal.org/gdal_calc.html with a conditional
syntax?
Hi Andreas, do you need to change the value of one specific pixel only? I
mean the pixel at [x,y] index?
giovanni
> Thanks,
> Andreas
> Am 2014-11-19 09:10, schrieb Carlos López PSIG:
>> Hi Andreas,
>> I also had problems to reclassify BIGTIFF with SAGA and GRASS!
>> Finally I used GDAL!
>> Best regards,
>> [2]
>> CARLOS LÓPEZ QUINTANILLA
>> www.psig.es [2]
>> carlos.lopez at psig.es
>> +34 699.680.261
>> 2014-11-19 9:05 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>>> Hi,
>>> I tried various tools, e.g.
>>> * SAGA reclassify
>>> * GRASS r.mapcalc
>>> Both work fine on smaller data sets, but fail on big data sets.
>>> This is on Win7 64bit, with the OSGeo4W installer. I have 8gb RAM
>>> and 40GB disk free on C:, more free space on other disks where the
>>> data resides.
>>> I am not totally sure if it is the Bigtiff issue or some other
>>> issue. It is just a guess that maybe I am hitting a limit with tiff.
>>> It is not fully transparent to me what Processing is doing in the
>>> background (what file formats with what options it creates).
>>> It may also be an issue with SAGA or GRASS directly.
>>> Thanks if you know anything,
>>> Andreas
>>> Am 2014-11-18 21:15, schrieb Giovanni Manghi:
>>> Hi,
>>> I am having a lot of troubles with large raster files and
>>> processing.
>>> The intermediate results can go >4GB. Processing stops with not so
>>> helpful error messages.
>>> I wonder if processing is hitting the 4GB limit. Can I force
>>> processing
>>> to use the BIGTIFF option or a raster format that can handle >4GB
>>> files?
>>> Hi Andreas, what tool specifically?
>>> cheers
>>> -- Giovanni --
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
>> Links:
>> [1] http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> [2] http://www.psig.es
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141119/5316cd35/attachment-0001.html>
