[Qgis-developer] Processing with raster files > 4GB
Andreas Neumann
a.neumann at carto.net
Wed Nov 19 01:44:24 PST 2014
Hi Giovanni,
I need to change all pixels that have the value of 249 to a value of
255. All other pixels should stay at their value.
Andreas
Am 2014-11-19 10:21, schrieb G. Allegri:
>> From my grayscale tiff images I want to replace one pixel value
> (249) with white (255). All other pixels should stay at the value they
> have.
> > I came across https://github.com/chiatt/gdal_reclassify [1] - but
> this reclassifies all pixels, not only selected ones.
> > Maybe I could use http://www.gdal.org/gdal_calc.html [2] with a
> conditional syntax?
> Hi Andreas, do you need to change the value of one specific pixel
> only? I mean the pixel at [x,y] index?
> giovanni
> > Thanks,
> > Andreas
> > Am 2014-11-19 09:10, schrieb Carlos López PSIG:
> >> Hi Andreas,
> >> I also had problems to reclassify BIGTIFF with SAGA and GRASS!
> >> Finally I used GDAL!
> >> Best regards,
> >> [2]
> >> CARLOS LÓPEZ QUINTANILLA
> >> www.psig.es [3] [2]
> >> carlos.lopez at psig.es
> >> +34 699.680.261
> >> 2014-11-19 9:05 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> >>> Hi,
> >>> I tried various tools, e.g.
> >>> * SAGA reclassify
> >>> * GRASS r.mapcalc
> >>> Both work fine on smaller data sets, but fail on big data sets.
> >>> This is on Win7 64bit, with the OSGeo4W installer. I have 8gb RAM
> >>> and 40GB disk free on C:, more free space on other disks where
> the
> >>> data resides.
> >>> I am not totally sure if it is the Bigtiff issue or some other
> >>> issue. It is just a guess that maybe I am hitting a limit with
> tiff.
> >>> It is not fully transparent to me what Processing is doing in the
> >>> background (what file formats with what options it creates).
> >>> It may also be an issue with SAGA or GRASS directly.
> >>> Thanks if you know anything,
> >>> Andreas
> >>> Am 2014-11-18 21:15, schrieb Giovanni Manghi:
> >>> Hi,
> >>> I am having a lot of troubles with large raster files and
> >>> processing.
> >>> The intermediate results can go >4GB. Processing stops with not
> so
> >>> helpful error messages.
> >>> I wonder if processing is hitting the 4GB limit. Can I force
> >>> processing
> >>> to use the BIGTIFF option or a raster format that can handle >4GB
> >>> files?
> >>> Hi Andreas, what tool specifically?
> >>> cheers
> >>> -- Giovanni --
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer [4] [1]
> >> Links:
> >> [1] http://lists.osgeo.org/mailman/listinfo/qgis-developer [4]
> >> [2] http://www.psig.es [3]
> Links:
> [1] https://github.com/chiatt/gdal_reclassify
> [2] http://www.gdal.org/gdal_calc.html
> [3] http://www.psig.es
> [4] http://lists.osgeo.org/mailman/listinfo/qgis-developer
