[Qgis-developer] pic2map plugin crashes qgis at installation
Milani Gillian
gillian.milani at romandie.com
Thu Nov 20 05:26:33 PST 2014
Hello,
A special plugin (pic2map in the repository https://documents.epfl.ch/ groups/l/la/lasig-unit/www/ pic2map/lasigRepository.xml <https://documents.epfl.ch/groups/l/la/lasig-unit/www/pic2map/lasigRepository.xml>) failed to install on some machines (not experienced by me but as feedback from tester). Traceback below.
If you want to test, you need the pyopengl bindings:
apt-get install python python-opengl python-qt4 python-qt4-gl
I've test personnly on several machine and cannot say if the crash is reproductable.
Someone has any hints of path ?
QGIS died on signal 11[New LWP 14900]
[New LWP 14899]
[New LWP 14898]
[New LWP 14897]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/ libthread_db.so.1".
0x00007f9fc1c8d199 in __libc_waitpid (pid=14913, stat_loc=0x7ffff2460b7c, options=0)
at ../sysdeps/unix/sysv/linux/ waitpid.c:40
40 ../sysdeps/unix/sysv/linux/ waitpid.c: File o directory non esistente.
[Current thread is 1 (Thread 0x7f9fca68a200 (LWP 14896))]
#0 0x00007f9fc1c8d199 in __libc_waitpid (pid=14913, stat_loc=0x7ffff2460b7c,
options=0) at ../sysdeps/unix/sysv/linux/ waitpid.c:40
resultvar = 142064536
oldtype = 0
#1 0x0000000000504b77 in qgisCrash(int) ()
No symbol table info available.
#2 <signal handler called>
No locals.
#3 __strcmp_ssse3 () at ../sysdeps/x86_64/multiarch/.. /strcmp.S:286
No locals.
#4 0x00007f9f45b844ef in QMetaType:: registerNormalizedType( QByteArray const&, void
(*)(void*), void* (*)(void const*), void (*)(void*), void* (*)(void*, void const*),
int, QFlags<QMetaType::TypeFlag>, QMetaObject const*) () from
/usr/lib/x86_64-linux-gnu/ libQt5Core.so.5
#5 0x00007f9f46091100 in ?? () from /usr/lib/x86_64-linux-gnu/ libQt5Gui.so.5
#6 0x00007f9fca4e69fa in call_init (l=<optimized out>, argc=argc at entry=3,
argv=argv at entry= 0x7ffff24669a8, env=env at entry=0x1deb4d0) at dl-init.c:78
j = <optimized out>
jm = <optimized out>
addrs = <optimized out>
init_array = <optimized out>
#7 0x00007f9fca4e6ae3 in call_init (env=0x1deb4d0, argv=0x7ffff24669a8, argc=3,
l=<optimized out>) at dl-init.c:36
No locals.
#8 _dl_init (main_map=main_map at entry= 0x4612b00, argc=3, argv=0x7ffff24669a8,
env=0x1deb4d0) at dl-init.c:126
preinit_array = <optimized out>
preinit_array_size = <optimized out>
i = 1
#9 0x00007f9fca4eac48 in dl_open_worker (a=a at entry=0x7ffff24615d8) at dl-open.c:577
args = 0x7ffff24615d8
file = <optimized out>
mode = <optimized out>
call_map = <optimized out>
dst = <optimized out>
__PRETTY_FUNCTION__ = "dl_open_worker"
new = <optimized out>
r = <optimized out>
reloc_mode = <optimized out>
nmaps = <optimized out>
l = <optimized out>
any_tls = <optimized out>
first_static_tls = <optimized out>
#10 0x00007f9fca4e68b4 in _dl_catch_error (objname=objname at entry= 0x7ffff24615c8,
errstring=errstring at entry= 0x7ffff24615d0, mallocedp=mallocedp at entry= 0x7ffff24615c7,
operate=operate at entry= 0x7f9fca4ea970 <dl_open_worker>,
args=args at entry= 0x7ffff24615d8) at dl-error.c:187
errcode = 0
c = {objname = 0x7ffff24615c8, errstring = 0x7ffff24615d0, malloced =
0x7ffff24615c7, errcode = 0x7ffff24614b4, env = {{__jmpbuf = {140737258067672,
1100602835762729759, 2147483650, 73463776, 140737258088872, 3, 1100602835825644319,
1118669940720587551}, __mask_was_saved = 0, __saved_mask = {__val = {140322487677008,
140324127448752, 140322487532928, 11782726505686307072, 1, 140737258068208, 115, 0,
140322487532928, 140737258067376, 140737258068144, 140737258067376, 140322220051785,
140737258067776, 1, 257}}}}}
catchp = 0x7f9fca68a1d0
old = <optimized out>
#11 0x00007f9fca4ea43b in _dl_open (file=0x460f7e0
"/usr/lib/python2.7/dist- packages/PyQt5/QtGui.so", mode=-2147483646,
caller_dlopen=<optimized out>, nsid=-2, argc=3, argv=0x7ffff24669a8, env=0x1deb4d0)
at dl-open.c:661
args = {file = 0x460f7e0 "/usr/lib/python2.7/dist- packages/PyQt5/QtGui.so",
mode = -2147483646, caller_dlopen = 0x7f9f4ffa2f45 <_PyImport_GetDynLoadFunc+293> ,
caller_dl_open = 0x7f9fb9b6f02b <dlopen_doit+91>, map = 0x4612b00, nsid = 0, argc =
3, argv = 0x7ffff24669a8, env = 0x1deb4d0}
objname = 0x7ffff24618b0 "initQtGui"
errstring = 0x7ffff24618b0 "initQtGui"
malloced = false
errcode = <optimized out>
__PRETTY_FUNCTION__ = "_dl_open"
#12 0x00007f9fb9b6f02b in dlopen_doit (a=a at entry=0x7ffff24617f0) at dlopen.c:66
args = 0x7ffff24617f0
#13 0x00007f9fca4e68b4 in _dl_catch_error (objname=0x1ad39c0, errstring=0x1ad39c8,
mallocedp=0x1ad39b8, operate=0x7f9fb9b6efd0 <dlopen_doit>, args=0x7ffff24617f0) at
dl-error.c:187
errcode = 32671
c = {objname = 0x1ad39c0, errstring = 0x1ad39c8, malloced = 0x1ad39b8,
errcode = 0x7ffff24616d4, env = {{__jmpbuf = {0, 1118783400970081055,
140737258067952, 2, 73459664, 73463776, 1100602835787895583, 1118669940720587551},
__mask_was_saved = 1342395295, __saved_mask = {__val = {206158430232,
140737258068000, 140737258067808, 11782726505686307072, 64, 140322487677008,
140322487677008, 73459670, 127, 40165680, 140320876527665, 816, 12, 60, 1,
140320876527708}}}}}
#14 0x00007f9fb9b6f5dd in _dlerror_run (operate=operate at entry= 0x7f9fb9b6efd0
<dlopen_doit>, args=args at entry= 0x7ffff24617f0) at dlerror.c:163
result = 0x1ad39b0
#15 0x00007f9fb9b6f0c1 in __dlopen (file=<optimized out>, mode=<optimized out>) at
dlopen.c:87
mode = 2, new = 0x7f9f50415390 <_Py_NoneStruct>, caller = 0x7f9f4ffa2f45
<_PyImport_GetDynLoadFunc+293> }
#16 0x00007f9f4ffa2f45 in _PyImport_GetDynLoadFunc () from
/usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#17 0x00007f9f4ff9168e in _PyImport_LoadDynamicModule () from
#18 0x00007f9f4ff92e01 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#19 0x00007f9f4ff934a4 in PyImport_ImportModuleLevel () from
#20 0x00007f9f50028378 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#21 0x00007f9f50021dec in PyEval_EvalFrameEx () from
#22 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#23 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#24 0x00007f9f4ffecb63 in PyObject_Call () from
#25 0x00007f9f50094667 in PyEval_CallObjectWithKeywords () from
#26 0x00007f9f5001de82 in PyEval_EvalFrameEx () from
#27 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#28 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#29 0x00007f9f500566c9 in PyImport_ExecCodeModuleEx () from
#30 0x00007f9f5005781e in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#31 0x00007f9f4ff92e01 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#32 0x00007f9f4ff934a4 in PyImport_ImportModuleLevel () from
#33 0x00007f9f50028378 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#34 0x00007f9f50021dec in PyEval_EvalFrameEx () from
#35 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#36 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#37 0x00007f9f4ffecb63 in PyObject_Call () from
#38 0x00007f9f50094667 in PyEval_CallObjectWithKeywords () from
#39 0x00007f9f5001de82 in PyEval_EvalFrameEx () from
#40 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#41 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#42 0x00007f9f500566c9 in PyImport_ExecCodeModuleEx () from
#43 0x00007f9f5005781e in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#44 0x00007f9f4ff92e01 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#45 0x00007f9f4ff9387e in PyImport_ImportModuleLevel () from
#46 0x00007f9f50028378 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#47 0x00007f9f50021dec in PyEval_EvalFrameEx () from
#48 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#49 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#50 0x00007f9f4ffecb63 in PyObject_Call () from
#51 0x00007f9f50094667 in PyEval_CallObjectWithKeywords () from
#52 0x00007f9f5001de82 in PyEval_EvalFrameEx () from
#53 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#54 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#55 0x00007f9f500566c9 in PyImport_ExecCodeModuleEx () from
#56 0x00007f9f5005781e in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#57 0x00007f9f4ff92e01 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#58 0x00007f9f4ff933ed in PyImport_ImportModuleLevel () from
#59 0x00007f9f50028378 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#60 0x00007f9f50021dec in PyEval_EvalFrameEx () from
#61 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#62 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#63 0x00007f9f4ffecb63 in PyObject_Call () from
#64 0x00007f9f50094667 in PyEval_CallObjectWithKeywords () from
#65 0x00007f9f5001de82 in PyEval_EvalFrameEx () from
#66 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#67 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#68 0x00007f9f500566c9 in PyImport_ExecCodeModuleEx () from
#69 0x00007f9f5005781e in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#70 0x00007f9f4ff92e01 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#71 0x00007f9f4ff933ed in PyImport_ImportModuleLevel () from
#72 0x00007f9f50028378 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#73 0x00007f9f50021dec in PyEval_EvalFrameEx () from
#74 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#75 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#76 0x00007f9f4ffecb63 in PyObject_Call () from
#77 0x00007f9f50094667 in PyEval_CallObjectWithKeywords () from
#78 0x00007f9f5001de82 in PyEval_EvalFrameEx () from
#79 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#80 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#81 0x00007f9f500566c9 in PyImport_ExecCodeModuleEx () from
#82 0x00007f9f5005781e in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#83 0x00007f9f50057d1d in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#84 0x00007f9f4ff92e01 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#85 0x00007f9f4ff9387e in PyImport_ImportModuleLevel () from
#86 0x00007f9f50028378 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#87 0x00007f9f50021dec in PyEval_EvalFrameEx () from
#88 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#89 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#90 0x00007f9f4ffecb63 in PyObject_Call () from
#91 0x00007f9f50094667 in PyEval_CallObjectWithKeywords () from
#92 0x00007f9f5001de82 in PyEval_EvalFrameEx () from
#93 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#94 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#95 0x00007f9f5003ef26 in PyRun_StringFlags () from
#96 0x00007f9f50021711 in PyEval_EvalFrameEx () from
#97 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#98 0x00007f9f500220f1 in PyEval_EvalFrameEx () from
#99 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#100 0x00007f9f500220f1 in PyEval_EvalFrameEx () from
#101 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#102 0x00007f9f4ffe42ac in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#103 0x00007f9f4ffecb63 in PyObject_Call () from
#104 0x00007f9f5002eff5 in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#105 0x00007f9f4ffecb63 in PyObject_Call () from
#106 0x00007f9f4ff42d1d in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#107 0x00007f9f4ff64caf in ?? () from /usr/lib/x86_64-linux-gnu/ libpython2.7.so.1.0
#108 0x00007f9f4ffecb63 in PyObject_Call () from
#109 0x00007f9f500203c2 in PyEval_EvalFrameEx () from
#110 0x00007f9f500221fd in PyEval_EvalFrameEx () from
#111 0x00007f9f50095110 in PyEval_EvalCodeEx () from
#112 0x00007f9f5001c5b9 in PyEval_EvalCode () from
#113 0x00007f9f5003ef26 in PyRun_StringFlags () from
#114 0x00007f9f50433a59 in QgsPythonUtilsImpl:: runStringUnsafe(QString const&, bool)
() from /usr/lib/libqgispython.so.2.6. 0
#115 0x00007f9f50435586 in QgsPythonUtilsImpl::runString( QString const&, QString,
bool) () from /usr/lib/libqgispython.so.2.6. 0
#116 0x000000000054dc1b in QgsPythonRunnerImpl:: runCommand(QString, QString) ()
#117 0x00007f9fc6832642 in QgsPythonRunner::run(QString, QString) () from
/usr/lib/libqgis_core.so.2.6.0
#118 0x000000000054bbb4 in QgisApp::QgisApp( QSplashScreen*, bool, QWidget*,
QFlags<Qt::WindowType>) ()
#119 0x00000000004fe65d in main ()
gdb returned 0
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141120/d467f935/attachment-0001.html>
