[Qgis-developer] PostGIS tables with missing gemoetries: how to handle them?
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Nov 20 05:32:28 PST 2014
I wasn't aware of this. Although I do not understand why one should put
points and lines in the _same_ table, geometries are allowed to be NULL
if the field does not have a NOT NULL constraint. I see two possible
solutions
1) mark the dataset as having no geometry
2) (preferred) do only load datasets which have a geometry
reasoning: As one can load any relation geometryless I would assume when
loading the relation _with geometries_ there are geometries contained.
I am aware that solution 2) can be achieved with the user applying a
filter like <code>"geom_column" IS NOT NULL</code> to the layer but
that's for advanced users only
Bernhard
Am 20.11.2014 14:07, schrieb Paolo Cavallini:
> Hi all.
> If one has a pg table with records with a missing geometry (e.g. there are records
> with a geom in a point column, others in a line column, others with both), the table
> will show only the records with a geom; if I click on Show all, I also get records
> without a geom. Of course, selecting a record like this and clicking on Zoom to
> selected does nothing.
> I'm unsure this is the least confusing behaviour for the user: opinions?
> All the best.
__________ Information from ESET Mail Security, version of virus signature database 10754 (20141120) __________
The message was checked by ESET Mail Security.
http://www.eset.com
