[Qgis-developer] Problems with developing custom c++ qgis application with QtCreator and MSVC2008 on Windows
Nejia nejia at spaceyes.fr
Fri Nov 21 00:02:15 PST 2014
I use the same environment of Qgis to write c++ plugins:
http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc14
to add raster layer:
m_ptInterface->addRasterLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json&pretty=true","raster");
Regards,
Nejia
-----Message d'origine-----
De : qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de eliu1234
Envoyé : jeudi 20 novembre 2014 21:40
À : qgis-developer at lists.osgeo.org
Objet : Re: [Qgis-developer] Problems with developing custom c++ qgis application with QtCreator and MSVC2008 on Windows
Do you have a system setup that can write qgis c++ application? If you do, can you create a valid raster layer from that?
Nejia wrote
> 1- see my response here
> http://stackoverflow.com/questions/26920574/cannot-find-qgsapplication
> -h-and
> -other-header-files/27035138#27035138
> De :
> qgis-developer-bounces at .osgeo
> [mailto:
> Envoyé : mercredi 19 novembre 2014 17:39 À :
> qgis-developer at .osgeo
> 1. So in the .proj file, what do i need to change?
> 2. My Python works in this case, it is the C++ part that is not working.
> Nejia wrote
>> Hi,
>> 1- QGIS and Qt libraries shipped with Osgeo4W are compiled using
>> release mode so if you want to debug your application you can use
>> RelWithDebInfo mode.
>> 2- see:
>> http://gis.stackexchange.com/questions/120823/how-to-load-a-wms-layer
>> using-
>> pyqgis
>> http://ieqgis.wordpress.com/2014/08/09/adding-esris-online-world-imag
>> e
>> ry-dat
>> aset-to-qgis/
>> Cheers
>> Nejia
> http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-
> qgis-a
> pplication-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5173838.ht
> ml Sent from the Quantum GIS - Developer mailing list archive at
> Nabble.com.
> Qgis-developer mailing list
> Qgis-developer at .osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-qgis-application-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5174130.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer at lists.osgeo.org
