[Qgis-developer] Problems with developing custom c++ qgis application with QtCreator and MSVC2008 on Windows
eliu1234
lby20102 at hotmail.com
Fri Nov 21 12:35:38 PST 2014
What is the m_ptInterface in your code?
Nejia wrote
> I use the same environment of Qgis to write c++ plugins:
> http://htmlpreview.github.io/?https://raw.github.com/qgis/QGIS/master/doc/INSTALL.html#toc14
> to add raster layer:
> m_ptInterface->addRasterLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer?f=json&pretty=true","raster");
> Regards,
> Nejia
> -----Message d'origine-----
> De :
> qgis-developer-bounces at .osgeo
> [mailto:
> ] De la part de eliu1234
> Envoyé : jeudi 20 novembre 2014 21:40
> À :
> qgis-developer at .osgeo
> Objet : Re: [Qgis-developer] Problems with developing custom c++ qgis
> Do you have a system setup that can write qgis c++ application? If you do,
> can you create a valid raster layer from that?
> Nejia wrote
>> 1- see my response here
>> http://stackoverflow.com/questions/26920574/cannot-find-qgsapplication
>> -h-and
>> -other-header-files/27035138#27035138
>> De :
>> [mailto:
>> Envoyé : mercredi 19 novembre 2014 17:39 À :
>> 1. So in the .proj file, what do i need to change?
>> 2. My Python works in this case, it is the C++ part that is not working.
>> Nejia wrote
>>> Hi,
>>> 1- QGIS and Qt libraries shipped with Osgeo4W are compiled using
>>> release mode so if you want to debug your application you can use
>>> RelWithDebInfo mode.
>>> 2- see:
>>> http://gis.stackexchange.com/questions/120823/how-to-load-a-wms-layer
>>> using-
>>> pyqgis
>>> http://ieqgis.wordpress.com/2014/08/09/adding-esris-online-world-imag
>>> e
>>> ry-dat
>>> aset-to-qgis/
>>> Cheers
>>> Nejia
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-
>> qgis-a
>> pplication-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5173838.ht
>> ml Sent from the Quantum GIS - Developer mailing list archive at
>> Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-qgis-application-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5174130.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-developing-custom-c-qgis-application-with-QtCreator-and-MSVC2008-on-Windows-tp5173711p5174285.html
