[Qgis-developer] Contrast Enhancement
alexia.mondot at free.fr
Wed Nov 26 04:30:35 PST 2014
Thanks for your reply.
I've contributed to this plugin :P
The line you pointed to me is the line setting the renderer.
It is used to set the X contrast enhancement.
In my actual code,
i had
renderer = theRasterLayer.renderer()
renderer.setRedContrastEnhancement( redEnhancement)
renderer.setGreenContrastEnhancement( greenEnhancement )
renderer.setBlueContrastEnhancement( blueEnhancement )
I changed it to :
theRasterLayer.renderer().setRedContrastEnhancement( redEnhancement)
theRasterLayer.renderer().setGreenContrastEnhancement( greenEnhancement )
theRasterLayer.renderer().setBlueContrastEnhancement( blueEnhancement)
to test if maybe it was a problem with my object renderer. I didn't changed anything, but I've let this writing.
Regards,
Alexia
----- Mail original -----
Nejia <nejia at spaceyes.fr> a écrit :
> Hi,
> You can see ?Contrast Homogenizer? plugin that you can download it
> from Qgis Plugins - Official Repository
> <http://plugins.qgis.org/plugins/plugins.xml?qgis=2.6>
> File contrastHomogenizer.py line 249
> Regards,
> Nejia
De: "Alexia Mondot" <alexia.mondot at free.fr>
À: qgis-developer at lists.osgeo.org
Envoyé: Mercredi 26 Novembre 2014 01:07:44
Objet: [Qgis-developer] Contrast Enhancement
Hi all,
I have some problems to apply new stretching values to my layer
I have a function which allows to adapt the stretching of my image without the raster layer properties dialog.
When I open an image with my plugin, I display it on the canvas, I open my own histograms, and I can move the min max stretch of the 3 displayed bands.
It works well. But, when i save the project, i reopen it, I want to change the image stretching, it does nothing. The values are set, but it seems that the layer renderer is not updated.
Here is my stretching code :
print canvas
print "layer :", theRasterLayer
# type of layer : raster, vector, other
typeOfLayer = theRasterLayer.type()
dataProvider = theRasterLayer.dataProvider()
# the layer has to be a raster layer
if typeOfLayer == 1 :
if (theRasterLayer.rasterType() == 0 ) and theRasterLayer.renderer():
elif theRasterLayer.rasterType() == 2 and theRasterLayer.renderer():
min_red, max_red = values[0]
min_green, max_green = values[1]
min_blue, max_blue = values[2]
redEnhancement = QgsContrastEnhancement( dataProvider.dataType( 0 ) )
greenEnhancement = QgsContrastEnhancement( dataProvider.dataType( 1 ) )
blueEnhancement = QgsContrastEnhancement( dataProvider.dataType( 2 ) )
#set stretch to min max
redEnhancement.setMinimumValue( min_red )
redEnhancement.setMaximumValue( max_red )
greenEnhancement.setMinimumValue( min_green )
greenEnhancement.setMaximumValue( max_green )
blueEnhancement.setMinimumValue( min_blue )
blueEnhancement.setMaximumValue( max_blue )
redEnhancement.setContrastEnhancementAlgorithm(1)
greenEnhancement.setContrastEnhancementAlgorithm(1)
blueEnhancement.setContrastEnhancementAlgorithm(1)
print "blue enhancement", blueEnhancement
print "blue max", blueEnhancement.maximumValue()
print "blue min", blueEnhancement.minimumValue()
theRasterLayer.triggerRepaint()
print theRasterLayer.renderer().blueContrastEnhancement()
print theRasterLayer.renderer().blueContrastEnhancement().minimumValue()
print theRasterLayer.renderer().blueContrastEnhancement().maximumValue()
canvas.refresh()
canvas.repaint()
In my case, the canvas, is the main canvas, I have checked I work on the good one comparing the print canvas and the python console with iface.mapCanvas().
I know :
* both cases run this function.
* the minimum and maximum values of contrast enhancement are the same in my two prints (before and after the setXContrastEnhancement) (so the theRasterLayer.renderer().blueContrastEnhancement() seems to be well set)
* these values are the good ones
* they aren't displayed in the raster layer properties dialog
* my raster layer source is ok
* when i do these steps on the QGIS python console with the layer iface.mapCanvas().currentLayer() which points to the same file, it works
layer = iface.mapCanvas().currentLayer()
blue_en = QgsContrastEnhancement( layer.dataProvider().dataType(2))
blue_en.setMinimumValue(150)
blue_en.setMaximumValue(350)
blue_en.setContrastEnhancementAlgorithm(1)
layer.renderer().setBlueContrastEnhancement(blue_en)
layer.triggerRepaint()
What have I missed ?
Thanks by advance,
Alexia
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
