[Qgis-developer] OGR VRT and SrcSQL
Arnaud Morvan
arnaud.morvan at camptocamp.com
Wed Nov 26 05:05:03 PST 2014
After instrospection,
when adding to QGIS an 'OGR VRT' layer with SrcSql tag,
iterarator with spatial filter return no features.
This seems to be due to OGR.
Does anybody know a workaround about this ?
Arnaud
> I am working with OGR VRT files in QGIS.
> When I use the "SrcLayer" tag, all works correctly.
> But when I use "SrcSQL" tag, QGIS seems to load the file correctly, but
> nothing appears in the canvas.
> exemple:
> <OGRVRTDataSource>
> <OGRVRTLayer name="test_shp_sql">
> <SrcDataSource relativeToVRT="1">test.shp</SrcDataSource>
> <SrcSQL dialect="sqlite">SELECT * FROM test</SrcSQL>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> all attributes are correctly displayed in the attribute table.
> when I use Save As ... to another shapefile, the new file display correctly.
> "ogrinfo -la" gives me exactly the same results for "SrcLayer" and
> "SrcSQL" tags.
> I've also tried the getWKT plugin which give me the same result for
> features from the two layers.
> I do not understand what goes wrong : OGR or QGIS ?
> Arnaud
> Qgis-developer mailing list
