[Qgis-developer] Core dump when starting QGIS
Alessandro Pasotti
apasotti at gmail.com
Sun Nov 30 23:50:29 PST 2014
the same happened to me yesterday when upgrading from 12.04 to 14.04.
When I launched QGIS the second time it ran without errors.
2014-12-01 8:04 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Hi,
> I recently upgraded from Kubuntu 14.04 to 14.10. With the current master I
> get a core dump when starting QGIS. I removed the build directory and
> recreated the settings with ccmake. The compile works fine but when I start
> QGIS I get a core dump. Here are the startup messages:
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_US]
> Warning: Bus::open: Can not get ibus-daemon's address.
> IBusInputContext::createInputContext: no connection to ibus-daemon
> Warning: QGraphicsScene::addItem: item has already been added to this scene
> QGIS died on signal 11Could not attach to process. If your uid matches the
> uid of the target
> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> again as the root user. For more details, see /etc/sysctl.d/10-ptrace.conf
> ptrace: Operation not permitted.
> No thread selected
> No stack.
> gdb returned 0
> Aborted (core dumped)
> I see the splash screen and immediately get a core dump. I don't even see
> the main application window.
> I wonder if there is a library problem after my Ubuntu update?
> Thank you if you have any idea what I could do to solve my problem.
> Andreas
> Qgis-developer mailing list
Alessandro Pasotti
w3: www.itopen.it
