[Qgis-developer] QGIS 2.4 and 2.5: default transparency for select not honored?
Luca Manganelli luca76 at gmail.com
Wed Oct 1 01:24:21 PDT 2014
I found a problem with QGIS 2.4 and 2.5 yesterday build.
When you set the defeult the color for selections and you set the
alpha channel (i.e. to 25%), at next QGIS startup only the color
(without the alpha channel) is taken, until you modify the alpha
channel from the project options window.
To reproduce it:
 1. open qgis with empty project
 2. set the select color with transparency
 3. close qgis
 4. reopen qgis
 5. load some layers
 6. select one geometry: you'll see that the transparency value is
totally ignored
 7. set the transparency from the options
 8. now the selection is transparent
happens on both 2.4 and 2.5
