[Qgis-developer] Possible bug in composer
Carlos López PSIG carlos.lopez at psig.es
Fri Oct 3 13:13:00 PDT 2014
I think that I've found a possible bug in Composer.
I created a composer, I added a map, and I saved "Main properties" like
"Cache".
Then Save the project, close, and then when I open in Main properties
convert to "Rectangle"!
This produces that the map doesn't show correctly.
Is it a bug??
Should I open a ticket?
Best regards,
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141003/56192079/attachment.html>
