[Qgis-developer] Possible bug in composer
Carlos López PSIG
carlos.lopez at psig.es
Fri Oct 3 13:29:56 PDT 2014
I forgot to say that I'm testing the version 2.5 in ubuntu 14.04 LTS 64
bits.
I'm going to testing more....
* <http://www.psig.es>*
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2014-10-03 22:13 GMT+02:00 Carlos López PSIG <carlos.lopez at psig.es>:
> Hi,
> I think that I've found a possible bug in Composer.
> I created a composer, I added a map, and I saved "Main properties" like
> "Cache".
> Then Save the project, close, and then when I open in Main properties
> convert to "Rectangle"!
> This produces that the map doesn't show correctly.
> Is it a bug??
> Should I open a ticket?
> Best regards,
> www.psig.es
> +34 699.680.261
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141003/061b7643/attachment.html>
