[Qgis-developer] Possible bug in composer
Nyall Dawson nyall.dawson at gmail.com
Fri Oct 3 13:55:53 PDT 2014
> 2014-10-03 22:13 GMT+02:00 Carlos López PSIG <carlos.lopez at psig.es>:
>> Hi,
>> I think that I've found a possible bug in Composer.
>> I created a composer, I added a map, and I saved "Main properties" like
"Cache".
>> Then Save the project, close, and then when I open in Main properties
convert to "Rectangle"!
>> This produces that the map doesn't show correctly.
>> Is it a bug??
>> Should I open a ticket?
Hi Carlos,
There's an existing issue for this:
http://hub.qgis.org/issues/6085
Unfortunately it's caused by a bug in the Qt libraries, so we need to wait
until it is fixed upstream.
Cheers,
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141004/3a9903d5/attachment.html>
