[Qgis-developer] missing qscimod4.sip is stille there
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Tue Oct 7 01:40:39 PDT 2014
stefan at antigua:/$ cd /
stefan at antigua:/$ pwd
stefan at antigua:/$ sudo find . -iname "*.sip" | xargs grep qscimod
./home/stefan/Develop/src/qgis_master/python/gui/gui.sip:%Import Qsci/qscimod4.sip
QSCI_SIP_DIR is „set“ to QSCI_SIP_DIR-NOTFOUND.
What is this good for btw ?
Regards
Stefan
Von: G. Allegri [mailto:giohappy at gmail.com]
Gesendet: Dienstag, 7. Oktober 2014 10:28
An: Ziegler Stefan
Cc: qgis-developer
Betreff: Re: [Qgis-developer] missing qscimod4.sip is stille there
If I'm not wrong you're searching only in your home folder...
That file is required by gui.sip, as you can see. If it cannot be found the compiler shows the error (the build works fine the second time you launch it but then you get the Python error on QGIS startup).
The only solution for me was unsetting QSCI_SIP_DIR to disable this sip part.
2014-10-07 10:20 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch<mailto:Stefan.Ziegler at bd.so.ch>>:
The only thing I find is:
I’m on a fresh installed 14.04.
Regards
Stefan
Von: G. Allegri [mailto:giohappy at gmail.com<mailto:giohappy at gmail.com>]
Gesendet: Dienstag, 7. Oktober 2014 10:12
An: Ziegler Stefan
Cc: qgis-developer
Can you find that file on your machine? I can't....
Where should it be located?
I fear there was some problem with packages upgrading, but I can't find out where.
giovanni
2014-10-07 10:01 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch<mailto:Stefan.Ziegler at bd.so.ch>>:
Strange, I’m able to compile master with python bindings on Ubuntu 14.04.
Regards
Stefan
Von: qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org> [mailto:qgis-developer-bounces at lists.osgeo.org<mailto:qgis-developer-bounces at lists.osgeo.org>] Im Auftrag von G. Allegri
Gesendet: Dienstag, 7. Oktober 2014 09:54
An: qgis-developer
Betreff: [Qgis-developer] missing qscimod4.sip is stille there
The problem with missing qscimod4.sip from some Debian/Ubuntu packages seems to be still an issue. Recently I upgraded to Ubuntu 14.04 and I cannot sompile the sip parts of Python yet.
Nathan suggested [1] to disable the sip parts related to the code editors for the moment, but it seems it hasn't been done. Have you found different solutions to the problem?
Giovanni
[1] http://lists.osgeo.org/pipermail/qgis-developer/2014-July/033928.html
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141007/036d96b3/attachment-0001.html>
