[Qgis-developer] missing qscimod4.sip is stille there
G. Allegri
giohappy at gmail.com
Tue Oct 7 01:49:31 PDT 2014
QSCI_SIP_DIR-NOTFOUND turns QScintilla off. In my case the QSCI_SIP_DIR was
found but it was without the qscimod4.sip file. In this case QScintilla is
detected and turned on but then the error happens.
I had to set the option to QSCI_SIP_DIR-NOTFOUND to disable the feature...
Giovanni
2014-10-07 10:40 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch>:
> stefan at antigua:/$ cd /
> stefan at antigua:/$ pwd
> stefan at antigua:/$ sudo find . -iname "*.sip" | xargs grep qscimod
> ./home/stefan/Develop/src/qgis_master/python/gui/gui.sip:%Import
> Qsci/qscimod4.sip
> QSCI_SIP_DIR is „set“ to QSCI_SIP_DIR-NOTFOUND.
> What is this good for btw ?
> Regards
> Stefan
> *Von:* G. Allegri [mailto:giohappy at gmail.com]
> *Gesendet:* Dienstag, 7. Oktober 2014 10:28
> *An:* Ziegler Stefan
> *Cc:* qgis-developer
> *Betreff:* Re: [Qgis-developer] missing qscimod4.sip is stille there
> If I'm not wrong you're searching only in your home folder...
> That file is required by gui.sip, as you can see. If it cannot be found
> the compiler shows the error (the build works fine the second time you
> launch it but then you get the Python error on QGIS startup).
> The only solution for me was unsetting QSCI_SIP_DIR to disable this sip
> part.
> 2014-10-07 10:20 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch>:
> The only thing I find is:
> Qsci/qscimod4.sip
> I’m on a fresh installed 14.04.
> Regards
> Stefan
> *Gesendet:* Dienstag, 7. Oktober 2014 10:12
> Can you find that file on your machine? I can't....
> Where should it be located?
> I fear there was some problem with packages upgrading, but I can't find
> out where.
> giovanni
> 2014-10-07 10:01 GMT+02:00 Ziegler Stefan <Stefan.Ziegler at bd.so.ch>:
> Strange, I’m able to compile master with python bindings on Ubuntu 14.04.
> Regards
> Stefan
> *Von:* qgis-developer-bounces at lists.osgeo.org [mailto:
> qgis-developer-bounces at lists.osgeo.org] *Im Auftrag von *G. Allegri
> *Gesendet:* Dienstag, 7. Oktober 2014 09:54
> *An:* qgis-developer
> *Betreff:* [Qgis-developer] missing qscimod4.sip is stille there
> The problem with missing qscimod4.sip from some Debian/Ubuntu packages
> seems to be still an issue. Recently I upgraded to Ubuntu 14.04 and I
> cannot sompile the sip parts of Python yet.
> Nathan suggested [1] to disable the sip parts related to the code editors
> for the moment, but it seems it hasn't been done. Have you found different
> solutions to the problem?
> Giovanni
> [1] http://lists.osgeo.org/pipermail/qgis-developer/2014-July/033928.html
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Giovanni Allegri
> Giovanni Allegri
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141007/85928a4a/attachment.html>
