[Qgis-developer] opening same table twice
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Oct 7 05:46:00 PDT 2014
IMHO the current behaviour is not optimal. I often see my users having
the same table opened several times because the expected behaviour is
that if it is already open it comes to focus (similar as with opening
files). If the layer has many features opening the same table a second
(or third) time is awkard as it takes some time.
So how about having an option "Open only one instance of a layer's
table" that is ticked by default? Just untick if you need to compare
tables (e.g. with different filters applied).
Bernhard
Am 07.10.2014 14:35, schrieb Matthias Kuhn:
> Hi Raymond,
> Just discussed this last week with Denis who thought that sometimes this
> is intentional (comparing two tables).
> We thought about having the possibility to have a split view on the
> table. Once this is possible we could prevent the attribute table from
> being opened several times for the same layer.
> Opinions?
> Matthias
> On 07.10.2014 13:57, Raymond Nijssen wrote:
>> Not sure if I met a feature or a bug...
>> I can open the same attribute table multiple times. I would expect,
>> when I open it the second time, QGIS would just show/focus on the
>> window containing the already opened table.
>> Is this meant to be this way?
>> Regards,
>> Raymond
__________ Information from ESET Mail Security, version of virus signature database 10524 (20141007) __________
The message was checked by ESET Mail Security.
http://www.eset.com
