[Qgis-developer] Virtual Fields - Allow adding fields out of edit mode
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Oct 7 05:56:21 PDT 2014
Hi Matthias,
Am 07.10.2014 14:40, schrieb Matthias Kuhn:
> Hi Bernhard,
> On 07.10.2014 14:28, Bernhard Ströbl wrote:
>>>> tested with e5850f3
>>>> to your question: I think the current editing-mode behavior is
>>>> intuitive. What is not intuitive is that the expression editor can
>>>> only be launched when adding a virtual field. I am aware that I can
>>>> add a (permanent) field with the field calculator but this whole
>>>> business is IMHO not consistent.
>>>> This would be consistent:
>>>> 1) in field calculator if choosing to add a new field offer to make it
>>>> virtual or permanent (permanent being default)
>>> It could go there indeed, good idea.
>> will the field calcuator be active all the time then?
>> just thinking of consequences....
> Yes
>>>> 2) make add-field dialog be the same no matter if adding a permanent
>>>> or virtual field.
>>> I don't completely follow. Do you propose to remove the "virtual field"
>>> from the "add field" in favor of 1) or is the intention something else?
>> no, proposals 1) and 2) are independent from each other.
>> proposal 2) means, that the expression builder should be offered when
>> adding a permanent field, too, thus not changing the dialog when user
>> changes his choice of permanent/virtual.
>> Scenario is: user wants to add a permanent field and fill it with an
>> expression. Now it is either
>> 1) add field and accept
>> 2) open calculator, choose field
>> 3) define expression and accept
>> or:
>> 1) set editable
>> 2) open calculator
>> future behaviour would be:
>> 1) add field
>> 2) define expression and accept
> I think if the user wants to add a permanent field with the help of an
> expression the current solution with the field calculator is fine. I
> don't see any benefit that the "add field" dialog would have over that.
it does not really have any, but I was wondering why I can use an
expression for virtual fields and not for permanent fields
> On the other hand defining the virtual fields in the field calculator
> (and removing them from "add field") could make things more coherent.
+1, this would make the expression thing in the "add field" dialog needless
add/remove field would be only for working on the data structure; the
layer must be in editing mode, which makes your original question
obolete :) or now it is applicable to the calculator
all the best
Bernhard
> Any opinions about this?
> Matthias
__________ Information from ESET Mail Security, version of virus signature database 10524 (20141007) __________
The message was checked by ESET Mail Security.
http://www.eset.com
