[Qgis-developer] Virtual Fields - Allow adding fields out of edit mode
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Oct 7 06:11:58 PDT 2014
Am 07.10.2014 15:07, schrieb Matthias Kuhn:
> Hi
> On 07.10.2014 14:56, Bernhard Ströbl wrote:
>>> I think if the user wants to add a permanent field with the help of an
>>> expression the current solution with the field calculator is fine. I
>>> don't see any benefit that the "add field" dialog would have over that.
>> it does not really have any, but I was wondering why I can use an
>> expression for virtual fields and not for permanent fields
>>> On the other hand defining the virtual fields in the field calculator
>>> (and removing them from "add field") could make things more coherent.
>> +1, this would make the expression thing in the "add field" dialog
>> needless
>> add/remove field would be only for working on the data structure; the
>> layer must be in editing mode, which makes your original question
>> obolete :) or now it is applicable to the calculator
> Remove field would still be available out of edit mode to remove virtual
> fields.
> Add field would only be available in edit mode. But the field calculator
> instead available out of edit mode.
ok, sounds good
Bernhard
> Best
> Matthias
> __________ Information from ESET Mail Security, version of virus signature database 10524 (20141007) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
http://www.eset.com
