[Qgis-developer] Virtual Fields - Allow adding fields out of edit mode
Matthias Kuhn matthias.kuhn at gmx.ch
Mon Oct 13 09:11:47 PDT 2014
Hi all,
The changes have been merged to master today.
  * Virtual fields are now defined from the field calculator.
  * The field calculator is always available, regardless of provider
support and edit mode.
  * If an action from the field calculator requires to turn edit mode
on, the user will be notified on the field calculator dialog that this
will happen automatically when clicking ok.
Please test this and open issue reports if things are not working as
expected. Thank you very much.
Matthias
