[Qgis-developer] Virtual Fields - Allow adding fields out of edit mode
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Oct 13 22:36:33 PDT 2014
Hi Matthias,
thank you for your work!
However I have some small issues and a bug [1]
- I do not see any notification when not in edit mode but my action
requires edit mode (edit mode is turned on, though, when clicking OK)
- shouldn't "create virtual field" be the default when layer is not in
edit mode?
- could the check box "create virtual field" be placed to the right of
"create a new field"?
all the best
Bernhard
[1] http://hub.qgis.org/issues/11403
Am 13.10.2014 18:11, schrieb Matthias Kuhn:
> Hi all,
> The changes have been merged to master today.
> * Virtual fields are now defined from the field calculator.
> * The field calculator is always available, regardless of provider
> support and edit mode.
> * If an action from the field calculator requires to turn edit mode
> on, the user will be notified on the field calculator dialog that this
> will happen automatically when clicking ok.
> Please test this and open issue reports if things are not working as
> expected. Thank you very much.
> Matthias
__________ Information from ESET Mail Security, version of virus signature database 10558 (20141014) __________
The message was checked by ESET Mail Security.
http://www.eset.com
