[Qgis-developer] What does mean "empty tables" in "attribute table" item properties in a print composer?
    Junior Delaz
    delazj at gmail.com
    Wed Oct  8 14:53:00 PDT 2014
Thanks Nyall. This is what I suspected.
Then, none of the "empty tables" options should work on the frames in the
example above, right?
But actually, "Draw empty cells" option does have effect on them. Isn't it
a bug?
2014-10-08 22:33 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 08/10/2014 10:20 pm, "Junior Delaz" <delazj at gmail.com> wrote:
> > Hi all,
> > I try to understand the use case of empty tables in print composer and
> am still confused.
> > Create a new print composer and add an attribute table item
> > set its height enough to show more rows than the maximal values of
> features you set.
> > Add a second frame to this item.
> > Is this second frame considered as "empty table" (as no feature
> attribute will be displayed inside)?
> No. This behavior only triggers when the entire table is empty. It is
> designed for atlas prints, where the table's contents are being filtered by
> the atlas. In this scenario it's possible that no records match the filter
> for a particular atlas feature and you need to handle empty tables.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141008/7e930378/attachment.html>
