[Qgis-developer] Trouble with PostGis plugin
Chris Crook ccrook at linz.govt.nz
Thu Oct 9 23:31:52 PDT 2014
Hi Walter
When you connect to the PostGis database make sure that you have selected the "Use estimated metadata" option - this optimises the connection for large datasets - see attached screenshot.  This should greatly improve the connection times for postigs.  (If you are already doing this then may need to look further!)
Cheers
Chris
________________________________________
Sent: 10 October 2014 02:29
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Trouble with PostGis plugin
sorry, no special plugin; just that build in PostGis tool.
mainly i need to the the queries going to the server in order to optimize
some indexes.
even adding EXPLAIn to the Query whould help a lot.
regards
walter
View this message in context: http://osgeo-org.1560.x6.nabble.com/Trouble-with-PostGis-plugin-tp5166669p5166687.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
Name: Screenshot from 2014-10-10 19:33:49.png
Type: image/png
Desc: Screenshot from 2014-10-10 19:33:49.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141010/bf843454/attachment-0001.png>
