[Qgis-developer] Trouble with PostGis plugin
    Sandro Santilli
    strk at keybit.net
    Fri Oct 10 04:10:31 PDT 2014
On Fri, Oct 10, 2014 at 03:56:05AM -0700, walter.nordmann wrote:
> Chris Crook wrote
> > Hi Walter
> > When you connect to the PostGis database make sure that you have selected
> > the "Use estimated metadata" option - this optimises the connection for
> > large datasets - see attached screenshot.  This should greatly improve the
> > connection times for postigs.  (If you are already doing this then may
> > need to look further!)
> "Use estimated metadata" is true and i see (in wireshark!) qgis is only
> fetching 100 samples to get the geometry. But even that needs a very long
> time.
> I think, Postgis is doing a sequential search but i'm no shure about that.
> But why does Qgis check the geometry? it is allready known and should not be
> necessary.
Can you send the whole query ?
I think there's a class of such issues with big tables that need be
addressed (and secured with some automated testcase).
> This part of Qgis is for me like a Black Box: select your data and wait. No
> loggin, no infos, nothing. Just wait.
You can open some of the box by connecting to the database
and looking at the pg_stat_activity table.
It would contain querying being processed.
> That is very frustrating in the developement-phase of a map. Killed the
> Qgis-Process dozend times a day, loaded my last save and started again. :(
I feel your pain.
If you can, please test this issue with the current master branch so if
something has to be fixed it has a chance to be in time for version 2.6
(due in 2 weeks).
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
