[Qgis-developer] Qgis-server in single-symbol renderer don't use the metadata title.
René-Luc Dhont rldhont at gmail.com
Mon Oct 13 23:57:49 PDT 2014
Hi Andrea,
It's a regression since the merge of the new Layer Tree.
Can you open an issue ?
Thanks,
René-Luc
Le 13/10/2014 20:49, Andrea Peri a écrit :
> Hi,
> In qgis-server (i tested with last dev),
> when use a category renderer,
> and request a GetLegendGraphics.
> The return use the LayerName as title of the layer in the Legend.
> Like this sample show:
> http://tinyurl.com/kwvoo6h
> Or this other:
> http://tinyurl.com/qaravsm
> AFAIK should be better to have as Legend Title the title insert into
> the Metadata Title (when filled).
> Infact the layername is often a non-understandable code. Instead the
> Metadata Title is a Human Understandable value.
> The choice to put the layername istead of the Metadata title (when
> available) is a bug or a wanted feature. ?
> Thx.
