[Qgis-developer] Qgis-server in single-symbol renderer don't use the metadata title.
    Andrea Peri
    aperi2007 at gmail.com
    Tue Oct 14 01:08:27 PDT 2014
I open the ticket.
http://hub.qgis.org/issues/11406
Meanwhile I see that contrarly to the first email, the category also
wrong to put the title in the legend response.
Thx,
Andrea.
2014-10-14 8:57 GMT+02:00 René-Luc Dhont <rldhont at gmail.com>:
> Hi Andrea,
> It's a regression since the merge of the new Layer Tree.
> Can you open an issue ?
> Thanks,
> René-Luc
> Le 13/10/2014 20:49, Andrea Peri a écrit :
>> Hi,
>> In qgis-server (i tested with last dev),
>> when use a category renderer,
>> and request a GetLegendGraphics.
>> The return use the LayerName as title of the layer in the Legend.
>> Like this sample show:
>> http://tinyurl.com/kwvoo6h
>> Or this other:
>> http://tinyurl.com/qaravsm
>> AFAIK should be better to have as Legend Title the title insert into
>> the Metadata Title (when filled).
>> Infact the layername is often a non-understandable code. Instead the
>> Metadata Title is a Human Understandable value.
>> The choice to put the layername istead of the Metadata title (when
>> available) is a bug or a wanted feature. ?
>> Thx.
> Qgis-developer mailing list
Andrea Peri
qwerty àèìòù
