[Qgis-developer] weekly build problem
Stott, James fmrojst at fylkesmannen.no
Tue Oct 14 22:42:47 PDT 2014
Are there any plugins that could be causing this problem? Seeing as the problem exists over 2 different versions of QGIS I would recommend checking.
I have had similar (think it was with version 2 and 2.2) and the problem was solved by turning off all plugins. I was then able to add the plugins in again one by one to find the plugin causing the problem.
Fra: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] På vegne av Angie Rudolph
Sendt: 15. oktober 2014 01:17
Til: qgis-developer at lists.osgeo.org
Emne: [Qgis-developer] weekly build problem
I installed the windows weekly build on 9/26/14 and QGIS has been behaving poorly ever since.  When I add
a simple shapefile, stored on my local hard drive, turning the layer off an on takes up to 10 seconds.
I have since tried to uninstall the weekly build and install a stable version of QGIS (2.4) but the problem now remains.
Is there something else that needs to be uninstalled such as visual C++, etc?
Angie Rudolph, GISP
Greenwood Mapping, Inc.
c:(208)-201-5699
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141015/56352658/attachment-0001.html>
