[Qgis-developer] weekly build problem
Mathieu Pellerin
nirvn.asia at gmail.com
Tue Oct 14 22:56:42 PDT 2014
Rename your .qgis2 folder in your user profile directory (eg
c:\users\my_name\.qgis2) to something else to try a vanilla qgis
configuration. If speed goes back to normal, problem lies with a plugin, or
less likely a non-default qgis setting.
M
On 15 Oct 2014 12:52, "Stott, James" <fmrojst at fylkesmannen.no> wrote:
> Are there any plugins that could be causing this problem? Seeing as the
> problem exists over 2 different versions of QGIS I would recommend checking.
> I have had similar (think it was with version 2 and 2.2) and the problem
> was solved by turning off all plugins. I was then able to add the plugins
> in again one by one to find the plugin causing the problem.
> *Fra:* qgis-developer-bounces at lists.osgeo.org [mailto:
> qgis-developer-bounces at lists.osgeo.org] *På vegne av* Angie Rudolph
> *Sendt:* 15. oktober 2014 01:17
> *Til:* qgis-developer at lists.osgeo.org
> *Emne:* [Qgis-developer] weekly build problem
> I installed the windows weekly build on 9/26/14 and QGIS has been behaving
> poorly ever since. When I add
> a simple shapefile, stored on my local hard drive, turning the layer off
> an on takes up to 10 seconds.
> I have since tried to uninstall the weekly build and install a stable
> version of QGIS (2.4) but the problem now remains.
> Is there something else that needs to be uninstalled such as visual C++,
> etc?
> Angie Rudolph, GISP
> Greenwood Mapping, Inc.
> c:(208)-201-5699
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141015/aa9f85c9/attachment.html>
